Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
SOURCE: i need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Testimonial: "thank you, that was very helpful"
SOURCE: f:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
SOURCE: My bosch logixx 8 sensitive front load washer is
I have a Bosch Logixx was bought in April 2009 and I have had this problem several times, it seems like a button or coin can block the pump, you may need to try turn machine off and pull out plug, take the drainage hose out of the holder, remove sealing cap, allow detergent solution to flow out, put the closing cap back on hose, carefully unscrew the pupm cver, see if anythings stuck there, re-insert pump cover etc. I have had to call repairmen out 3 times ( pump blocked not covered under warranty) and had pump replaced, I WOULD NOT BUY BOSCH ever againa s there after care service is rubbish and I paid $1800 for this metal junk.
SOURCE: I have a Bosch Logixx
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Testimonial: "Thanks - the engineer is coming later today. "
