Utility-stop-0-0-stop-0-1 for service mode. choose clear data, then supply count then ok to clear. On/ Off the machine it will work as usual.
Great, it works again, thank you
My Konica printer is showing maintenance call(M2)
Please help....
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
please follow the instruction
my konika biznub 215 trouble c3451
Hy my bizhub 195 show MaintenanceCall 2 plz help now
My konica minolta bizhub 215
No duplex pepar
C3451 service call please solution
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: Konica Minolta bizhub 163 Display
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
