I have direct tv so I use this remote. I bought the tv 46MF401B/F7 magnavox. I use the format button on the direct tv remote and it works good except I can not get the tv to go full wide screen. Can this be done without having to buy a remote. I have tried the buttons on the side of the tv but didn't work for me. Thanks
SOURCE: I dont have my remote and i need to switch the
Not cheap:
http://www.remotes.com/store/magnavox/32mf339b.html
Also try EBAY.
SOURCE: I have a Magnavox 42MF439B LCD TV. It was working
Maybe the problem is not from cables but from HDMI hole/jack, rusted or something
SOURCE: Magnavox 19MD359B F7 19 in
You have a bad capacitor in the power supply. If you can remove the back cover, you may see a bulged capacitor or two. Replace these and your TV will come back to life. I'm sorry, I do not have capacitor values and locations at this moment. But, the fix should be fairly simple. If you have some elctronic experience, you can fix this. Thanks for asking and show all hands of support!
SOURCE: bought a magnavox hdtv modle #19md357b137b at an
This is generaly a 4 digit code that one would put i during set up.
most people don't use that option and most of the time (if it hasn't been used) it's 0000.
if that doesn't work, you may have to go back to where you bought it or contact the manufacturer
SOURCE: magnavox 32md359b/f7
Main Board bad. The part number is A91F3-MPW S. Change this board fix the problem.
