This is all I can find, might do the trick;
When changing the multiplexer to NTSC or PAL all other settings
are returned to the factory defaults.
The multiplexer can be used with either NTSC or PAL systems.
To set it up for NTSC operation:
1) Turn off the power
2) Press and hold the and {M} buttons.
3) Turn on the power
To set up the multiplexer for PAL operation:
2) Press and hold the and buttons.
Password Code User1 (1111)
User2 (2222)
User3 (3333)
User4 (4444)
Supervisor (5555)
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
