SOURCE: numbers locked in on Dell Laptop
Look for the Num Lock key written in blue, press the FN key and press it. It will turn off the number keypad.
SOURCE: laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
SOURCE: number lock won't turn on
When enabled, this allows the user to type numbers by pressing the keys on the number pad, rather than having them act as up, down, left, right, page up, end, and so forth.
in bios is where you can set number lock to enable at start up
so restart and enter set up(bios) and change it to lock numbers at start up
if you need more help just let me know
electech
SOURCE: Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
SOURCE: keyboard stuck on fn
I found this on another site, and it worked on my Vostro 1510:
Try pressing shift + numlock (Scrolllock in blue) to toggle the Fn feature.
Normal numlock comes on, so press it again by itself to turn that off.
