SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
SOURCE: key symbol showing
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
off. Try the door gently. Means the machine is locked, for children. I think if you do
it again it locks.
SOURCE: bosch classixx 6 1400 machine
F21 relates to a motor or control board fault. However, it is also caused by spikes in the mains and can be spurious. To reset it. Turn the appliance knob to the off or reset position, 12 o'clock. Turn the knob to the 6 o'clock position. Press and hold the spin button. While holding it, turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds. Release the button. Turn the knob to off. When your turn it back on it should have cleared the error code
SOURCE: Bosch Classixx 6 1200 express has an error code F21 what is it
it is a motor or pcb fault this is a reset code as follows,
turn dial to off 12 0clock position then turn to 6 oclock,
press and hold the spin buttonat same time turn it to 7 oclock,continue to hold the spin buttonfor 5 seconds,release button,turn off.
next time you turn on the error code should have gone ,
if it does not work go through the proceedure again i had to try it 3 times but it does work
