Directed Dei Valet 561r Remote Start/Keyless Entry Logo
A
Anonymous Posted on Apr 04, 2014
Astrostart hst 5225 wont charge - Directed Dei Valet 561r Remote Start/Keyless Entry
When trying to start with fob, starter turns but vehicle will not start. using rss-5225 AstroStart any advice to get it to start with fob?
If the starter turns but the vehicle won't start when using an AstroStart RSS-5225, it's likely a vehicle-specific issue. Check for any issues with the vehicle's ignition, fuel, or electrical system. Consult a professional mechanic for a thorough diagnosis and repair.
Will this battery work in my astrostart HST 5225 remote? I bought a RRS 5225 it plugged in but full charge it worked but didn't last a day. did I just get a dud?
REMOTE START, CRAZY ADD ON.
WHY NOT ASK THEM FOR SUPPORT.
MY GUESS IS WRONG BATTERY.
WHAT MEANS RRS? A HUGE TYPO FOR RSS???????? WOW IF TRUE.
https://www.astrostart.com/Products/RemoteStartSecurity/4306/RSS-5225.aspx
i READ THE MANUAL THERE RSS5225
IT SAYS CLEAR AS DAY THIS.
:Your remote is powered by an internal rechargeable battery that can only be serviced by an authorized Directed dealeR"
READ THIS? PAGES ON CHARGING IT
https://www.directeddealers.com/manuals/OG/AstroStart/RSS-5225_OG-Eng-2.pdf
PAGE 7 CHARGING WITH USB
THE FOB IS 13 YEARS OLD RIGHT.
AND NO BATTERY LASTS FOR 13YEARS, AND MUST BE REPLACED
SO PULL IT OUT AND POST PART NUMBERS ON IT.
How to shut truck off with astro start hst 5225 remote?
Hold the key and the question mark buttons and that should work to cancel the runtime, panic and alarm activated modes
1helpful
How to shut off truck with remote hst 5225 astro start?
Your truck should shut off automatically after 5-15 minutes without the key in and 'on' due to built in antitheft. If it won't shut the truck down on it's own without the key that unit is most likely faulty.
Disconnect the ignition coils and this will safely shut your truck off if need be until it can get replaced.
If you just want to turn it off, and the unit is ok, you have to manually cycle the key.
I have a new remote a Hst-5225 it will not charge? I plug it in and doesn’t light up or anything. And is there an on/off switch for the remote start? Just bought a 2006 Trailblazer SS. Has astrostart...
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the 20 times I f ixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
2answers
How do I fix error code 8 on my astrostart RSS-5225?
Disconnect one of the battery cables from its terminal for five minutes. Reconnect the cable to the post and it should be reset and your car should start. Be sure to tighten the clamp on the cable. It is very important to have a secure cable attachment to the battery post.
Trouble shooting astrostart remote starter for hst 5224 model
Leave the ignition key on for 10 minutes until the security light goes off. You may have to do this three times for a 30-minute total for a relearn procedure
Top Directed Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
