Question about Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage
Garage doors opens on its own, after being close for hours
I have come home to find my garage door open the first time i thought my fault but the second time I spoke to the neighbors and was told the door open on it's own around 9:00 a.m. I leave for work at 5:30 a.m.
    Problem Solver:
  • 33 Answers
Your neighbours might have the same frequency as you. Change your code on remote and system.
Posted on Mar 02, 2019
    Habit-Forming:
    Scholar:
  • 105 Answers
One check is to use the lock feature on your hard-wired door button. This will disable ALL remotes. See if it opens on it's own. If it does it is not the remote but possible a mouse or cracked wires shorting across the opener wire to make a contact. It could be a faulty board if it does open to check this Disconnect the open wires "At" the opener, they are just push in type on most openers. If it still opens then its the board.
Hope I helped
    New Friend:
  • 59 Answers
Do you live near an airbase or military installation and find your garage door sometimes opens on its own? This is caused by interference from high power communication systems that can activate the radio receiver in your garage door opener.
Automatic Garage Door Closer
Posted on Nov 04, 2017
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Someone in your neighborhood may have the same garage door opener that you have and sharing the same code. Change your garage door opener code or buy a Genie Code Scrambler.
Posted on May 15, 2014
6ya staff
SOURCE:
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
Jul 14, 2016 | Sears Craftsman LiftMaster Chamberlain...
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
I have a Liftmaster Prof. 1/3 H.P. I close the garage with the garage door clicker, but when I come home hours later the garage door is OPEN. Please advise.
Very strange. I think there may be another remote being used unknowingly by someone or it is responding to someone else's garage door frequency. Is yours a rolling code type for enhanced security. If not it would be a good idea to upgrade.
Dec 18, 2014 | Building Materials
My garage door opener will open and close on its own
Someone may have the same frequency in the neighbourhood.
Sep 24, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Door will not close. led blinking 5 times
Is your door open or closed? If you release the door is it easy to open and close manually? Does the opener run with the door released?
Jun 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-Master garage door opener Model 1045-6 1/3 hp
Most residential garage door openers have a max. amount of cycles they can run per hour. Thus the difference between a residential opener which only needs to be opened a few times a day vs. a commercial opener which needs to open 10-20 times and hour. This could be your problem, you may be running too many cycles too soon. This would explain why it seems to work again after unplugging the power. You're resetting the unit. Hope this helps.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Garage Door. SilentMax 1000 3/4 HP Comparable Belt Drive Garage Logo
1,379 people viewed this question
Top Genie Home Experts
john h
Tom Chichester
Are you a Genie Home Expert? Answer questions, earn points and help others
