Question about Life Fitness 9500HR Next Generation Remanufactured Treadmill
Light out on wax lift board on treadmill
No power on treadmill screen and 1 light is out on the wax lift board
2 Suggested Answers
6ya staff
SOURCE:
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
Mar 01, 2015 | Life Fitness "Remanufactured 95Te...
What does activity zone keypad not detected mean
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control.
LifeFitness 95TE Treadmill Parts SPORTSMITH net
Jun 05, 2014 | Life Fitness 95te Treadmill 7 Inch Touch...
Activity zone keypad not detected
This means either the keypad is faulty or it has come unplugged. Check for loose 10 pin connection at display console or wax/lift control. LifeFitness 95TE Treadmill Parts SPORTSMITH net
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Life Fitness 9100 Next Generation...
Allready in the start up screen module comm error what is that
two possible issues
one unplug treadmill remove hood and make sure the main power cable to the motor controller box is in tight power back up and see if that worked
two you might have blown your overload resistor on the motor control board (mcb) . unplug treadmill and remove the motor control box . remove the motor control board out from inside the box and inspect it for damage and/on electrical burn smell. if you find damage you have to get it repaired. contact glide fitness products in santa ana california 1 866 637 4600 to get all information including shipping. it cost $200 plus shipping which is a deal considering a new one is $1000 . if you do send it in for repair remove the wax board and electrical componeton the outside of the box and put in a safe place as you will need to reinstall them on the new box the most common cause for the overload to blow is friction between the belt and the deck board ,if you have an auto waxer the nozzle is usually plugged clean the nozzle once a month . contact glide regarding non clogging wax if this is best for you
good luck
Dec 09, 2010 | Life Fitness 95Ti Treadmill 95 Ti
My treadmill says waxing needs refill maintainance required
1) Flip the treadmill on its side to expose the bottom 2) remove the two screws holding the rectangular metal wax cover 3) remove the wax cover 4) you should see a bag of wax, replace it with new 5) type in 5-1-2-5-Enter to reset the wax statistics
Jun 24, 2010 | Life Fitness 9000 Next Generation...
Treadmill get stop with a jrk whn power gets a cut..
Sounds like the wax lubrication has finally boiled off the belt the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
Feb 02, 2010 | Precor 9.21 Treadmill
In life fitness next generation operation elevation is not working.!What is the problem?
It will be one of three things: #1 faulty Wax/Lift circuit board that controls the lift motor,#2 the motor itself, or #3 a faulty home switch, which is the white plastic switch in the base of the machine which senses the home position or zero degrees elevation.
Sep 22, 2009 | Life Fitness 9500HR Next Generation...
Same problem
I would suggest that you reattach the two wire that their because the unit is pull too much current and that safety feature is to protect both motor and lower board from damage. If you have not been instructed by your local dealer about preventative maintenance Most Precor running are double sided, which means both surfaces are usable and are coated with wax. The easiest way without dismantling your unit is to follow this procedure:
You may purchase this wax product @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Aug 23, 2009 | Precor 9.21 Treadmill
Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
97 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Android Man
Android Man
Kenneth Simmons
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
