Kyocera FS-C5015N Laser Printer Logo
A
Anonymous Posted on Apr 04, 2014
Clear cued document - Kyocera FS-C5015N Laser Printer
New whirlpool microwave model WMH53521HZ-4, if I enter the wrong length of time on the cook time how do I clear it and enter a different time? On my previous microwave there was a clear/reset button.
On this microwave, you just need to enter the correct cooking time and power level. This will clear the previous time and power level that you entered. (This works since you need to use the Options button to do multi-stage cooking.)
The manual for the Whirlpool WMH53521HZ is available on the product site: https://www.whirlpool.com/kitchen/cooking/microwaves/over-the-range/p.2.1-cu.-ft.-over-the-range-microwave-with-steam-cooking.wmh53521hz.html . Scroll down to the Manuals & Guides section or use the link and expand the section. The current link to the manual is https://www.whirlpool.com/content/dam/global/documents/201705/UserGuide-W11047549-RevA.pdf .
I hope this helps.
(Note: the -4 indicates a minor difference between versions. Sometimes it indicates the color of the microwave.)
tip
Clear My Recent Documents in Windows XP
All the links of the recently used files are stored in the My Recent Documents in the Start Menu.
To clear My Recent Documents in Windows XP
Step 1. Right Click on Start Menu and click Properties it will open a new window.
Step 2. Click Customize and then the Advanced tab
Step 3. Click the button Clear List under Recent Documents on the lower right-side of the window
This will clear the My Recent Documents.
Learn and enjoy.
on Jul 08, 2010 • Computers & Internet
What is error code E3
If you have a gen one (finger ice maker) it means the th3 sensor is open. You will want a trusted technician to tackle this issue.
It keeps randomly printing the following: GET/DevMgmt/DiscoveryTree.xml HTTP 1.1 HOST:
To resolve this behavior, clear the Document Properties check box. To do this, follow these steps:
Word 2007
  1. Click the Microsoft Office Button, and then click Word Options.
  2. In the Printing Options area box, click to clear the Print document properties check box, and then click OK.
Word 2000, 2002 and 2003
  1. On the Tools menu, click Options, and then click the Print tab.
  2. In the Include with document area, click to clear the Document Properties check box, and then click OK.
How do I remove cued documents without printing them
Click Start - printers and Faxes - double click on your printer then you will see a list of documents that are queued to print.
Click on the print document you want to remove then click on Document at the top and then click Cancel.
Repeat for other print documents you want to cancel.
Printer appears to want to print out an infinite number of pages of gibberish from a document sent to it. Obviously, the document info somehow, somewhere screwed up. I don't need to waste an unknown number...
The document is probably not screwed up this happens usually when the computer is using the wrong printer driver. if the pdf looks ok on the screen try reinstalling the printer driver and resend the document. to clear the job from the printer just turn off the printer and clear the print que from the computer.
4helpful
2answers
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
2answers
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
2answers
I can't clear the print qeue of my HP 1350 all in one and a document is "stuck". Won't print and wont go away.
I assume you have gone to the 'printer' screen, high-lighted the document and then clicked on delete document. This takes forever - don't know why - but it does. Eventually the document will disappear. If you don't have the patience then reboot your computer.
The paper is stuck while printing and the message is clear the paper jam
when it stuck, just click start menu below, under settings and printers and faxes. Then find the printer and double click and cancel all documents clear. So after doing it restart again your pc and try print another document.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
