Can I use a class 10 micro card or must t be a class 2 mirco card?
SOURCE: It shows Sandisk logo and freezes there
Remove the SD card and try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
SOURCE: Expandable Memory
If music won't load onto Micro Sd card:
1) go to settings
2) go to USB mode
3)change to MSC format
Now you're good to go.
SOURCE: How can I use 8GB micro sd card on my Sansa e280
I believe if you upload rockbox http://www.rockbox.org/ to your sansa it will fix this.
SOURCE: Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
