Your owners manual will tell you what formats , audio and video codecs will be acceptable to the TV. Your usb memory stick file (avi, mp4,mkv, may play on your pc but not on the TV. Find a video file convertor program to fix your issue
as you did not provided the manufacturer (brand), model or version - we do not know if your tv is capable of direct play of .avi files, you need to go to the manufacturers site and check what supported formats are.
Do you have the PTA02 accessory for the TV? This is a USB 3D transmitter and comes with 2 pairs of Active 3D glasses. The screen of the 40PFL8605H is not a 3D TV by itself.
I hope this helps. If you have the 3D accessory plugged in, try turning off the TV and turning it back on if the software did not install properly. The final thing to check is the "codecs" for your 3D movies on the USB stick. Make sure that they are compatible with the TV.
There should be a button on your remote that says "TV/USB". Try clicking it, that should take you to a blue screen that says No Signal, click Input, and you should be able to access your cable from the list of Input sources. This happened to me today, very annoying and unnecessarily confusing, especially since most buttons you press result in a screen that reads "Not Available." Urrgghhh.
Hi Ganesh,
At this point what you can do is download and install a codec pack, which includes all necessary codecs for your computer, please download and install it from the following link.
http://www.free-codecs.com/download_soft.php?d=5012&s=775
Most probably the TV system is not compatible.
This VCR/DVD uses NTSC formate. Is the DVD in PAL formate. Also the Region code can be different. This DVD palys DVD-Disks with regional code 1 or All.
