please try to open the cover while the machine is on and close it back or remove the toner and putt it back sometimes the machine not register the new toner good, so you need to do this two or three times if this not help call a technician
This an error for out of toner. Make sure there is toner in the hopper. Do this by pushing down the hooked shaped clips on top of the hopper and at the same time move the slide to the right. Using a flashlight look into the hopper see if there is toner. There was also a mod kit for cleaning the toner sensor that should have been done. Return the slide back to normal position. Add toner if needed. If there is toner you will have to remove the developer unit , access from the bypass door. Unscrew the top of the developer unit, look to make sure that there is toner inside. Return to proper position when through. You will also have to reset the error after toner checks ( service mode ). Do this by inserting a straightend paper clip into hole located below control panel on left side. You should see a $ on control panel. Press * 4 *. Look for " ERROR ". Use arrows on screen to move through the different screens. Touch screen on error to highlight. Press OK. Turn off and back on main power switch ( lower right side ). To refill developer unit if needed is to go into service mode and *4* and look for INSTALL. Look for TONER-S. highlight and press OK. Copier will run and time down until developer is filled correctly. Reset key serveral times and copier should be OK. Run several 20 copy sets to test that toner will hold.
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
A couple of suggestions. 1. make sure there is not any plastic shipping tabs that need to be removed from the cartridge. 2. try reseating the cartridge. 3. Try replacing that cyan cartridge. It may be defective. Also make sure you use Minolta brand toners!
