SOURCE: how do I rotate the handlebar stem on gmc yukon xl road bike?
If the stem is installed backwards that means it is pointing at you when you are riding? To correct this you will need to remove the handlebars from the stem. This done by removing the two allen bolts front the front of the stem. Now loosen the two(may be only one) allen bolt heads on the side of the stem. Now rotate the stem. Reinstall the handlebars, front mounting plate and bolts (make sure the bolts are tight). Make sure the stem is straight and tighten the allen bolts on the side.
If the stem was installed incorrectly it may be a good idea to have the bike checked over by your local bike shop to insure nothing else is installed/adjusted incorrectly.
Hope this helps. If you need any other help you can contact me at [email protected] Thank you
SOURCE: I just bought a new gmc denali road bike. what size socket do i need to tighten the handlebars.
Normally these are 1/2 inch.
SOURCE: Denali GMC 700C Women's road bike wrong tires!!!
I know people will not agree with buying there, but Walmart bike tires are 5-15 dollars each and tubes can be 5-12 dollars each. Roughly 40 dollars to replace two tires and tubes. Keep that in mind when you go to buy a used bike on Craig's List that has two flats. Dawn, new rims can be cheap or expensive. I would assume that if you bought a bike that it has the correct rims and tires on it. Is this a question of not wanting "balloon tires" versus road bike tires?
