Question about LG WM-3677HW Front Load Washer / Dryer
Start button take long to activate and doors leak
When i hit start button it take10-15 min to start washing and also the door leaks too
    New Friend:
  • 43 Answers
When you press start button the signal is sent to the main board. The leak is from a bad bellow that rubber on you door, if your door is not damage. it's not sealing with the door.
Posted on May 03, 2014
6ya staff
SOURCE:
Anonymous
  • 75 Answers
SOURCE: leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Posted on Jul 25, 2008
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
Anonymous
  • 236 Answers
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Posted on Mar 16, 2009
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: LG front load washer -- water leaks
First, clean off the bottom of the door glass where it contacts the gray tub gasket when the door closes. Any hair or other build up can result in leakage. Second, if that does not completely solve your leak, you can move the location of the spring which holds the tub gasket from the very bottom (6 O'clock position) to the hinge area (9 O'clock position). Third: Sometimes, the reason you get a leak is due to the installation. If the washer was pushed into place by applying pressure in the center front of the washer, the outer front panel can be slightly deformed (inwerd) resulting in leakage from the door. If that is the case, sometimes you can remove the outer clamp and outer part of the gray seal and pull out on the front panel to correct the situation if it is not too severe, rather than replacing the entire front panel.
Posted on Jun 25, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: Leaking from bottom of front door
hi..
Try checking the rubber boot from the door opening to the drum for signs of hole or cracking..
thank u
rate me!!!
Posted on Aug 19, 2009
My wife hit pause during the wash cycle to remove BBs from my sons pocket. She opened the door removed the BBs closed the door and hit Play/Start when she got the error E27. I have unplugged the unit for...
  1. Hold down the "Allergy rinse" button, "Spin Selection" button at the same time.
  2. Turn the Wash selection knob to the left on "Cold". Result: You should see different codes flashing on screen, this is resetting the machine's error, and is exactly what we want.
  3. After a few seconds turn Wash selection knob to "Off".
  4. Turn machine back on.
Result: Your mashine should work
cheers
Aug 31, 2017 | Bosch WFVC5440UC Washer
Frigidaire Front Load Washer wont start!
sounds like you have a very unhappy control panel..unplug it, wait 5 min..and then plug it back in..if it does not reset, then you may want a repair job, no?
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000FS1 Error Message E41. I set up the machine, hit the start button, and I only get he PAU note across the screen. The washer will not start up. Ran the Diagnosis and come up with E41. ...
Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
Apr 08, 2011 | Frigidaire Washing Machines
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Machine wont restart after inadvertantly hitting the stop button instead of the pause button
I believe the final solution was to unplug the machine for several minutes. When it was plugged in again I hit one of the wash cycle buttons and after a minute or so the button indicating that the door was closed properly lit up and then the machine resumed it's cycle.
Aug 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door Error
Hiya... how long are you waiting? there is a timer door delay.. on nearly all washers now... usually around 2-5 mins!... Wait a few mins and see if this cures the prob.
Regards Faggly
Mar 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM-3677HW Front Load Washer / Dryer Logo
90 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
