Sometimes (but not always) my machine won't stop at the end of the cycle but instead will continue onto the other side of the dial, also when it does this, it starts filling with water and then won't stop filling until I manually shut the water feed off. It does appear to continue through the various parts of the cycle (spin, drain, etc) but all the while it keeps filling with water.
SOURCE: GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
SOURCE: water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
