Vision Fitness T9500 Treadmill Logo
A
Anonymous Posted on Apr 05, 2014
Control board buttons wont respond - Vision Fitness T9500 Treadmill
TV wont respond to the button controls (Cant find the remote)What do you suggest?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 • Dishwashers
Tv wont respond
The infrared signal that emits from the remote control is not with right frequency. Check it with fresh batteries. If it do not help you, replace the crystal inside the remote control's circuit board.
1helpful
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
My tv turns off and on and sometimes wont respond to the button or remote. I've taken the back off and all capacitors look good. Some people say motherboard some say power supply. Any ideas?
Tv turn on.Power LED indication light on solid green,have picture.Only problems it wouldn't respond to any controls wright?It the Tuner signal motherboard board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
5helpful
I hit power button then start start light flashes and wont start
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
1helpful
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Top Vision Fitness Exercise & Fitness Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Are you a Vision Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
