Vivitar ViviCam 35 Digital Camera Logo
A
Anonymous Posted on Apr 05, 2014
What is the self timer icon?
Explain icons in camera
For a Panasonic Lumix DMC FZ28, how do you set the self timer for taking fotos on a tripod?
You set the self timer with the round rocker switch on the back of the camera. Press the icon on the left side, the little clock shape. One press for 10 seconds delay, again for 2 seconds, again to cancel (icon will show on screen). Then press the shutter button- the shutter will fire after the delay.
How do i use the self timer on a nikon afshin matlabi
Press the shooting mode button (overlapping rectangles symbol) and rotate the main command dial until the self-timer icon (one-handed clock) is showing.
My F100 will only fire in the self timer mode. Solution?
Check the selector in the front lower right of the camera. Move it to M then S, then C, then back to S. Next: you need to adjust the setting from self timer back to normal, press the mode button and check the icon select from self timer to normal shooting mode.
How do I set the timer?
Press the self-timer button. It's the bottom part of the cross-shaped button on the back, marked with a clock icon. Each press of the button cycles between ON and OFF.
After pressing the shutter release button completely, the self-timer lamp lights for approximately ten seconds, blinks for approximately two seconds, then the picture is taken.
To cancel the self-timer, press the button again.
The self-timer is automatically canceled after one shot.
How do I get to the self timer?
Press Home key and see Clock icon in list, its self timer, select it and press shutter button to take picture, camera will take picture after 10 seconds.
Below image shows Timer Icon in your DSC-T70 camera.
2helpful
Self timer for the nikon n55
Press the self-timer button just to the right of the LCD panel and confirm that the self-timer icon appears. Press the shutter release halfway to focus and meter. Press the shutter the rest of the way to activate.To cancel, either turn the camera off or press the self-timer button until the self-timer icon disappears.
You can get a manual at http://www.butkus.org/chinon/nikon.htm
Timer
When you press the menu button while shooting select the self timer setting (second icon) and then select the clock icon without the '2' in it this is the 10 second setting.
Here is your missing manual:
http://www.fuji.fi/documents/12/a345_a350.pdf
I hope this helps!
Canon 40d self timer
The self timer icon should show up on the LCD panel, on top of the camera on the right side.
2helpful
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
