SOURCE: how to reset lamp meter
I have a PT-50LCX63 unit. After 5 years and 4 bulbs, a "reset lamp" warning showed up every time I turned on the tv. I have to say that after a few weeks, the message ceased on its own. I don't know if all models eventually reset or turn off, but I could not find any other information on the direct way of resetting. I find the warning a waste of time since the bulbs are good for 10 -14 months. Sadly I missed the class action suit that dealt with the premature lamp failures. I am looking for a new tv at this point. Bulbs have cost me $1200.00 since I bought it. The warning is supposed to allow you the option of replacing the lamp before it fails, Ha! what a joke...Thanks for reading.
SOURCE: The lamp hour meter needs to be reset for
This works for most Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
SOURCE: where do i locate lamp in my panasonic pt 52lcx66
The left speaker grill comes off then the lamp door will be behind there. Mind you if the lamp in your TV still works and you are changing it. Make sure that you let the TV cool down for a minimum of an hour before handling the old lamp. Also your lamp part number is TY-LA1001. Please take a moment to rate my answer. Thanks...
Testimonial: "Rite on thanx"
SOURCE: changed bulb on panasonic PT-52LCX66-k and cant reset timer.
I can help you reset the lamp timer for your Panasonic PT-52LCX66
Projection HDTV.
The buttons used are the TV's volume down and the
remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
SOURCE: how to change the bulb in my panasonic 52 inch
I can help you change your bulb and reset the lamp timer for your Panasonic PT-52LCX66
Projection HDTV.
I hope that helps.
