Question about Toshiba 32AV502R LCD TV
How can set up my HDTV Toshiba Mod 32AV502R to receive digital signals fron a indor digital antenna?
How can I do channel search to set up an OTA antenna?
6ya staff
SOURCE:
Jason Morris
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 13, 2009
Anonymous
  • 3 Answers
SOURCE: I have a 32
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Posted on Jun 23, 2009
Anonymous
SOURCE: With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
how do you change your HD setting say 480i to 1080p...
Posted on Dec 25, 2009
Chi Chu
  • 8457 Answers
SOURCE: RE: Toshiba 32AV502R 32
NO,Ur tv have problems.The Main Tuner Signal is dead,have burn electronics componnents.Still under warrenty call for service.Not Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Posted on Mar 17, 2010
specialistel
  • 8909 Answers
SOURCE: We have just received a
Hopefully, if you were to press the menu button and somewhere on the screen will be DTV. Select DTV and then you can run search again.
Hope that makes sense.
Posted on Mar 11, 2011
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I got an American model of LG. i can not tune it by auto nor manual can you please help
You can get a manual here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LG30.jsp . Click on the Support and then on the right hand side look for User's Manuals. Since the TV has a tuner for ATSC, NTSC, and Clear-QAM, the next question is what is your signal source? (analog, digital and unscrambled cable)
If you are using OTA, make sure that the input is set to Antenna. Use antennaweb.org or tvfool.com to check the direction to point your antenna and the appropriate antenna for your distance to the transmitter. antennaweb assumes an external antenna and is very conservative in the list of channels you should be able to receive. tvfool gives the stations available with different antennas. If you have several tvs connected to one source, you may need an amplifier in addition to the splitter. This also can help marginal signals come in since digital is either enough for the tuner to resolve or no signal. (Check splitters and amplifiers if you suddenly can't get a signal that you used to receive. Also check if the antenna has been turned.)
Menu > Channel > Auto Tuning or Manual Tuning. If Lock System is active, you will need the password. Auto Tuning only searches for digital or cable channels. The manual tuning option should provide the signal strength as well for digital stations (as well as letting you search for analog signals or all signals (digital, analog, cable).
Use the input Cable for coax cable connections. Other inputs will not allow you to search for channels since they are meant to be controlled by the set-top box feeding the system.
I hope this helps.
Nov 05, 2010 | LG 32LG30 32 in. LCD HDTV
How do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Oct 14, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Jan 13, 2009 | Toshiba 26AV500U 26 in. LCD HDTV
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Digital television signals
What type of digital tv signal? Satellite or OTA (Local Digital Antenna Channels)?
What type of equipment is the split signal going to? Straight to the tv's or some sort of Satellite or HDTV Tuner box?
Dec 19, 2007 | Motorola HDT101 DTV Receiver
Toshiba 32AV502R LCD TV Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
