I so not no how to take a selfie ands u cannot switch the camera and take or turn round and take, it is incredibly award I also cannot delete any videos or photos which is unexceptable please explain to me how to do this???!
To delete a photo, go to your Pictures Library. Find the photos you want to delete. Then, just lightly touch the photo and swipe your finger down a little. This will select that photo, you will see a check in the upper right corner of the photo if you did it right. You can continue to select as many photos you want in this way. You will see the option to Delete at the bottom of the screen as soon as you select the first photo. To deselect the photo, just swipe it down again.
To delete a video, go to the Videos folder located on your Desktop and open it up. You can then select each video like you did for the photos. To unselect it, just touch the check mark which is on the top left corner. When you have finished selecting all the videos you want to delete, just click on the big red X on the top toolbar.
One note though - my directions are based on Windows 8.1, so make sure you have installed all your updates.
Hope this helps!
John
While in the "Camera" app If you swipe in from the top or bottom of the screen you can select "Change Camera" to change to the rear facing camera to take "selfies".
If you pull the whole "Camera" app towards the right you will be able to cycle through the pictures you recently took. Swiping in from the top or bottom will again bring up a menu with an option to delete on it. If you want to delete pictures you took in the past then you go to the "Photos" app and do the same thing.
