SC122 [Cause] SDRB board is faulty. [Resolution] Replace the SCRB board and ground. AND SC122 occurs while scanning. Does not occur when scanning at the same magnification; occurs when copying and enlarging. [Cause] Scanner motor is faulty. [Resolution] Replace scanner motor. And one thing to check is to make sure the set screw that locks the cable pulley to the scanner drive shaft didn't back out or shear off.
Sounds like it is misfeeding from the Default tray (just not getting the paper into the machine). try removing the paper from the default tray, and use another one. If it works, then the paper feed rollers are the likely cause.
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
