Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
How to fix speecontro lever
What can I do to fix this myself?
I have ordered 3 cooks professional stand mixers for myself, my daughter and daughter in law and none of us am remove the mixing bowl - can you help?
On the right hand side of the unit there is a lever..lift the lever upwards and tilt back the head.
Then hold the bowl with both hands and twist to the left to remove the bowl.
Hope this helps you.
Dec 17, 2016 | Food Mixers
The kitchen aid mixer speed # 10 turns off when using it no matter the time used. How do I fix?
The cases need to be split and the lever needs to be fixed so that it grips the notches that hold it in place. It may be a bent lever or a loose pivot screw.
Dec 15, 2014 | Food Mixers
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Sep 13, 2014 | KitchenAid Kitchen Aid KSM150PSMY -...
Why will my kitchenaid stand mixer only go fast?
You will need to look under the back cover and make sure that the lever is moving the speed control plate out and in at the bottom. Out = fast. If that is moving freely and there are no broken pieces inside that back cover (springs, brass governor bits) then replacing the small pcb at the top with the 4 wires coming out of it should solve the problem.
May 21, 2014 | KitchenAid Food Mixers
Kitchenaid stand mixer K45SS willnot tilt the head I do not understand How to fix this problem
Put a towel on the bench and put it upside down on the towel. Wriggle lever and pedestal about and it may free up. The lever may be disengaged from the locking mechanism. The machine will need to come apart to fix any mechanism lever problems.
Aug 16, 2013 | Food Mixers
KitchenAid Speeds are offset
Ideally you need to fix what's bent and that normally would involve splitting the cases to get at and repair or change the speed control lever. If you don't want to do that then removing the back cover and altering the adjustments and maybe bending the switch contacts may make it operate at both ends of the speed control.
Oct 04, 2017 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid artisan ksm150 - Motor Head Locking Lever stuck in locked position
Get a copy of the Repair Part List of your model from Kitchenaid.com
Remove the Motor Housing (1). The Latch Lever (3) is connected to the Latch (10)
and held in place to the Lower Gearcase (5) by the Latch Bearing Screw (8). This
screw is visible from the outside and located near the Latch Lever.
Tighten this screw to fix your problem.
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Model K5SS -- The speed control lever will not stay in the slowest position - STIR - but will pop over to the next position - 2. Can I adjust anything to fix this problem?
Open up the Motor Housing and inspect the Switch Lever with Stud.
The Lower Gearcase has many depressions which allow the stud to
snap into it when the Speed Selection lever is moved. If the Stud
is worn out then there isn't much you can do but replacing it.
3184193 is the Switch Lever And Stud part number for your model.
Jul 03, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Replacement of lock and unlock lever
Look for my posts on "Removing the motor cover". The lock is under the motor head. Its easy to find and fix.
Jan 02, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Artisan Series Tilt-Head Stand Mixer Logo
52 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
