Pinout biagram
SOURCE: wiring pinout
red is 12 volt line that turns on with the key- the yellow is the 12 volt that stays on regardless of the key- the blue provides 12 volt to turn on an amp or to raise the antenna- the grey is the front right + speaker line-the grey with black right front speaker negative-white left front speaker + white/black is left front speaker negative- green is left rear speaker + green/black is left rear speaker negative purple is right rear speaker + purple/black is right rear speaker negative DO NOT GROUND THE SPEAKER NEGATIVE WIRES
SOURCE: i have the connector for
Hello
I've the installation manual for your Pioneer DEHP960MP with me, but it is in a different language, somewhat German I thinks. All the wiring digrams are it it. But I can't upload it to you. as this Fixiya site allows me to upload 50KB only, and the document is in adobe acrobat 9 format, and have about 300KB. If you are interseted, send me your email address through Fixya. I'll send you that file as an atachment. OK.
SOURCE: need pinouts diagram for Pioneer DEH-1600 CD Player
ok my friend has a 1999 ford f150 and we took the radio out to put in a poineer deh-1600 and we bought the connectors but one of the connectors doesn't fit and there was for wires were free when i got done the wires was a solid black with a white stripe, a solid orange with a white stripe, and a solid blue and a solid orange cable left tell me what do those wires goes to
SOURCE: pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
