If your Dango watch's second hand stops intermittently, there are a few things that could be causing the issue. Here are some possible reasons and solutions:
1. Low Battery: If the battery in your watch is running low, it could cause the second hand to stop. You may need to replace the battery in your watch. Check your watch's manual or take it to a watch repair shop to have the battery replaced. 2. Dirt or Debris: Dirt or debris can get inside your watch and cause the gears to stop moving properly. If this is the case, you may need to have your watch cleaned and serviced by a professional watch repair person. 3. Loose Second Hand: If the second hand on your watch is loose, it could cause it to stop intermittently. A loose second hand can be caused by a damaged pinion or cannon pinion. You may need to take your watch to a professional watch repair person to have it fixed. 4. Magnetic Interference: Magnetic fields can interfere with the movement of the gears inside a watch, causing it to stop or run erratically. If you have been around strong magnets or electronic devices, it could be causing the issue. Try moving your watch away from these devices to see if that helps. 5. Mechanical Issue: There may be a mechanical issue with your watch's movement that is causing the second hand to stop. This can be caused by a worn out gear or other component. You may need to take your watch to a professional watch repair person to have it fixed.
normally the watch chrono hands can be reset .
dependant on movement fitted.
*pull crown out to first position
* push and hold top right pusher.
* the second should start top sweep one complete revolution and then stop.
*when it stops use the lower right pusher to adjust.
*when at the 12 push the crown but in fully.
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"] To start/stop this, use the top button (Button "A"). To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A". The "second" hand is the small dial at the 9 O'clock position. In actuality, you 'could' start this and just not stop it... Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Hey, it sounds like your watch is just fine! A nice watch to inherit.
The small second hand on the sub-dial is your normal second hand.
The large second hand is the second timer for your chronograph feature.
It should only move when you hit the side buttons. One of them (usually the top plunger/ button) will start the Chrono timer and then hitting it again will stop it. The bottom button should reset the hand to the 12 o'clock/ zero marker.
If the large hand is not functioning at all then there may be something wrong with the watch; perhaps the buttons are not making full contact within the watch or the hand may be stuck and need repair.
Hope this answers your questions. Post more questions if need be.
Congrats on your new watch.
Hello! Absolutely astonished by this "solution" from escapement. This watch is working perfectly - it is simply giving its "end of battery life warning".
Your Tissot watch is a chronograph. The large second hand is for the stop watch only. There is another second hand by the six that is for the time. To get the large second hand to move hit the top right button, that works the stop watch. If you already knew this and your large second hand is not going around then there is something wrong with the watch either a battery or needs service.
