I saw you post from back in November, did you do anything with your clutch? I assume you are taking dc/UC errors to the console. Take a look at this post and see if will give you some insight to a DIY fix. Shout back if you have any questions. Here is a quick test for the TSD sensor but I believe you have a clutch issue. The TDS test is in the SM I’ve typed it out if you want to give a quick check. I’m sure you will pass and find the one-way roller clutch berings are dry/rusted and causing the dc/UC unbalance condition.
3.0 Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
3a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
3b. Press the Super Wash key display reads “in”…something like that.
3c. Press Delicates the Display will show “UC” (Unbalance Closed).
3d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
3e. Press Hand Wash.
3f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube or replace if necessary. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
Rich
