Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
SOURCE: AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
SOURCE: olevia not searching channels
try the following..
Q.
Why are the menu settings that I changed not being saved?
A.
The TV is in Showroom mode. The following steps will help you switch to Home mode.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q.
Why does my TV display "No Signal" or "Channel not in List"?
A.
Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
SOURCE: I cannot get my Olevia 226 T11 to do an auto
Check the Power Up setting to be sure it is starting up in HOME mode rather than SHOWROOM mode. In showroom mode, many settings cannot be changed.
SOURCE: Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual
Download
Polaroid FLM-2632
Service Manual Download
