SOURCE: the digital readings on the console of our Epic
Most likely the console is faulty. If the speed and incline buttons work and the numerical display is incomplete the console is at fault.
SOURCE: How do you get the cover off of the Epic 425 Mx
Dear Sir.
I will try to help you:
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
http://www.youtube.com/watch?v=H_ieEByRp34&feature=relmfu
http://www.youtube.com/watch?v=JhXR2BxOwWM&feature=related
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
With this you will fix it.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA C.A.
SOURCE: my epic 425 mx treadmill belt hesitates and rubs
Dear Sir:
I will try to help you.
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
http://www.youtube.com/watch?v=38w4PkiWIBY&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=HmVt-SHSYAI&feature=related
If you need further assistance, please reach me.sincerely. God bless you
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: Can the Epic 800 MX treadmill collapse for easy moving?
http://www.youtube.com/watch?v=hHeYb6CoK4c
Pleae do it carefully to avoid any injury. Try that another person get involved, and use Belt for your self. Use some protect equipment gloves, plactic for to protec the equipment.
sincerely
SOURCE: My Epic 425 Mx motor won't run even though power is on and display works
try to RUN the software calibration for diagnose, troubleshooting, fix it.
2) LUBE THE deck belt , this happen because the lack of maintenance schedule, maybe the deck is worn and need replace it. see the video and picture
3) lube the rollers bearing too very well.
4) test the input voltage motor, if there are the motor NEED repair,tight any wires connector for loose
5)measure the output voltage board, for input voltage motor, if there are NOT the board is faulty. use the DVOM OR VOM in both cases.
see the block d, tight any wires connector or wires looses
God bless you
