HOW TO RESET NS LCD32
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
SOURCE: i have the following tv, Insignia
Power supply board most likely, I have one just like it with the same problem in my shop right now.
SOURCE: Red tint on my TV, instead of all colors? Reset doesnt work?
Sounds like the component cables are misplaced. Check that, and report back.
SOURCE: Insignia 32" NS 32 q09
Since you don't mention how you're receiving the signal, I'm assuming you use a cable box or computer. Adjust the output settings (e.g. 720p, 1080p) on the box and then adjust your TV settings. If it's a computer, you'll need to adjust the video card settings to a compatible aspect ratio (e.g. 1366x768) for the desktop to display properly on the TV. Details can be found in the owner's manual.
