Hey friend, thank you for your inquiry!
I understand that your Frigidaire refrigerator is not cooling within the fresh food side but cooling in the freezer. I would check to assure that the vent assembly is not blocked by any food, if so remove the food and allow your refrigerator to cool down.
If there is no food blocking the vent place your hand in the fresh food side to see if any air is moving out of the damper. If you do not feel air coming out it could be an issue with your evaporator fan. Additionally we should check to make sure the gaskets are not bad. You can do that by using a dollar bill. Place the bill between the body of the fresh food and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. I hope this information has been helpful. - Matt
