We have a PIXMA MX410 COPIER/PRINTER/FAX. THE FAXES WE SEND ARE ALMOST ILLEGIBLE. IT DOES NOT SEEM TO BE SENDING A CLEAN IMAGE BY THE FAX
SOURCE: Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
SOURCE: I can receive faxes but when I send them they are illegible.
make sure glass is totally clean and pad is clean, also could be an issue with your scanner bulb
SOURCE: can only receive faxes not send faxes, when
Have you gone into fax param. and made sure sending is not turned off or set to manual?
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
