SOURCE: Change blade on Dewalt DC385 XRP reciprocating saw
The button is for changing the shoe position, you should find a lever on the opposite side that you need to lift up on to release the blade. You might be able to get a owners manual at Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number and it will direct you how to download one. Let me know if you need more help
SOURCE: I Have a Dewalt DC385 type 2 Reciprocating saw.
REMOVE THE BLADE !!!! take the handle apart and lift out the switch. keep track of the lock slide button and how it is installed. unplug the switch wires. carefully touch the wires you just unplugged onto the battery terminals. these wires lead directly to the motor. BEWARE.. if the motor components are good , the saw will run at FULL SPEED. you only need to tap the wires, DO NOT jamb them onto the battery. If the motor runs then most likely the switch is bad. If you know how to use a continuity tester then you can also check the switch. Bad moter likely culprtet is the brushes are crapped out.
SOURCE: what is the problem when a dewalt reciprocating
I am assuming you are refuring to the battery life. To be honest with you it is not a new problem. The Sawzall uses more power than the battery can store, so there don't last.
If this is a new problem for you that you are noticing less power with fresh batteries., They could be bad batteries. Barrow someones, if you can and see.
I hope this helps you. Please let me know if you have any further questions or if that this did help you.
SOURCE: I have a Dewalt DC385 Reciprocating saw, when I
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
SOURCE: replacing blade assembly on a dewalt 18v Reciprocating Saw Sawzall
Remove the foot, remove the boot (and yellow lever), pull shaft out all the way (so you have more room to work with), remove the spring clip from the clamp block, remove the lever and ball, the clamp block will then slide off once the wire clip that wraps around it is removed.
