I unplugged my TV for 5 minutes after 5 minutes I pressed the Power button on the side of the TV not the power button on remote for a full minute. Plugged the TV back in, pressed the power button and it turned on. Doing this essentially does a reset.
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Very likely the volume setting on your cable is set too high. The cable volume is separate from the TV volume. Once you lower the cable volume, then you can adjust your TV volume to find a happy medium that gives you more range between numbers. Have you already tried this?
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
try this..turn off ur tv by remote,press mute followed by 187 then power,if this work u shall see reset underneath the sub menu goto reset..the tv must turn off and on.donot explore other u might kill your tv!!
