It is refusing to connect to the internet through the router, and I have tried everything I could think of
Contact Arris.
http://www.arrrisi.com/consumer
Mark
Motorola Support
SOURCE: how to connect linksys router with aztech adsl modem
1-Go to ip address of aztech modem 192.168.1.1
2-Default usermname and password is "admin"
3-Go to quickstart-> Turn off firewall (uncheck)
4-Save changes
5-Connect modem to router's wan port
6-Go to router setup , and select connection type as dynamic ip.
7-Save and restart modem
Solution 2
1-Go to modem quickstart
2-Select connection type as bridge, save changes
3-Go to router's setup, select connection type as Ppoe, give ur username and password provided by internet provider
4-Save changes
5-Restart modem and router
SOURCE: setting up linksys wireless router with motorola 2210 dsl modem
Reset the DSL Modem and make sure the modem is setup for your DSL account information. You might have to call up your ISP for that information to be added. If that was done prior then the Router has to have the same information user name @ your ISP.net or .com and password. for PPOE. Make sure the router has it MTU set to 1492 for DSL.
1. unplug the modem
2. unplug the router
3. between both of them wait 30 seconds
4. all PCs should not be on
5. plug in back the modem
6. plug in back the router
7. Turn one one PC
8. login to the router and make sure it connects to the internet
Since your using Gig Router make sure that the WAN is to 10 if you have 6Mbps plan 15 to 30mbp plan go to 100 for WAN.
If you're still having issues, then you need 3rd level service tech from your ISP to check the DSL back at the office side to see how that's connecting to your modem. If that checks out okay, then have line tech come out and check the DSL going into the house. If that checks out good then it could be the a problem with the new router you have there you have updated the firmware for it yet?
If you have then the modem could be the problem. These are the steps you need to take to trouble shoot the problem. Check all connections make sure they're plugged in correctly. Make sure all DSL filters are working correctly one bad filter can throw the DSL off. Check each phone connected to a filter to see if its clear.
SOURCE: My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is 10.1.1.138 but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
SOURCE: Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
SOURCE: i cant get my motorola sb5101 surf board cable
I have a similar problem. The common denominator seems to be the SB5101. I have a brand new Belkin Surf 300N, same issue. The modem will not give DHCP to the router. I can connect fine via ethernet to the modem directly.
This modem seems to be a dinosaur.
