Televison & Video Logo
V
Veronica Posted on Apr 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LEDTV24FHDF No siginal, does the make contain freeview or do we need to purchase it?
Chad
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Apr 10, 2014
Chad
Expert
Level 2:
New Friend:
Answers
91
Questions
0
Helped
25607
Points
124
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
1helpful
How to set up freeview on a E32W13A-NZ
How do set up TV with Freeview built in
The above link is a good source for information regarding the connections to a TV. If your TV does not have a built-in digital converter for off air reception, you'll need to purchase one.
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
How do you get the freeview to work on a samsung 932MW
This model does not have a built-in Freeview tuner. You will need to attach an external Freeview tuner (or other device such as a PVR containing a tuner) to one of the TV's external inputs.
1helpful
Ldc tv with built in freeview wont tune to bbc 1 bbc 2, retuned 20 times still no bbc 1 bbc 2 . before i did retune i would receive bbc wales post code OL16 2RR North west
Buy a digital antena,or roof antena recieve better siginal,get everythings.Tries reset to factory setting retune again will get BBC1,BCC2 well get it back.
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
4helpful
How to record freeview programs off tv with built in freeview
I have recently purchased a TV with built in Freeview. How can record programs onto my VCR? How many scart cables do I need?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
