Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to
Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Hi emadhasabo , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
