SOURCE: reset nokia 6110 security code
type this code on ur handset and press dialing button.....but this will refresh your phone completely and all the data saved in phone will be lost. after dialin this code the phone will ask to restart, after restarting original settings will be restored as before when u brought ur phone new.
the code is *#7370#
SOURCE: forgot lock code
hi there,
how are you..
here i write some instruction that you can follow to unlock your phone....
hope it will help you to deal this matter.
any further question that you want to know you can log on this site for additional information.
http://gleez.com/articles/did-you-know/nokia-secret-codes
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
SOURCE: forgot my lock code for nokia 6275i
Nokia *#7328748263373738# Resets the security code to default(ie,12345)
other solution r
software flashed and reloaded
device replace
check out here
http://www.scribd.com/doc/299040/Nokia-Universal-codes-
SOURCE: i forgot my security code for nokia 6080 pls help.
Go to the site http://unlockme.co.uk and enter your phone’s IMIE number and press Enter then u’ll get the master code of your phone. 2. This master code can be used as lock code when we are asked for the security code.
3.But always we can’t remember master code and we want to use an easier lock-code then we can set a new security code of our own wish by giving the Master-code as our old security code when asked for old code while resetting security code.
e.g.NOKIA 6600
Tools -> Settings ->(scroll down) security -> Phone and SIM ->(scroll down) Lock Code
Then it asks for old code where u can type the master code and then set the new code as you wish.
When during formatting u are asked for lock code you can also enter Master code.
To get IMIE of your phone type *#06# on screen of your phones.
tell me if it doesnt work
