Yamaha the same note on each octave won't play
SOURCE: Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
SOURCE: Yamaha Gran Touch problems
bit late. I have had the same problem. I replaced the optical module which solved the problem for me. The optical module is located above the keyboard and is used for scanning the keyboard.
Good luck,
F van Duijvenvoorde
SOURCE: My Yamaha PRS-293 will not play any of the E keys
The key switches are scanned as a matrix. One of the matrix wires has broken or connector/cable is not making it... It will be a connection in common with the non-working keys.
Here is schematic:
http://elektrotanya.com/yamaha_psr-293_sm.pdf/download.html
On page 40 on the board labelled 61H-MK and the connector DMLCD-CN401 the connections to pins 11 and 12 with signal names N14 and N24 have become broken or disconnected before they get to the processor board.
Since these lines are NEAR an edge, the cable could be not quite in the connector at one end or the other. These two wires are what triggers the E and the A# key signals. There are TWO contacts per key as one closes first then the other... this is how they measure key velocity.
Testimonial: "Thank you so much. You saved a good keyboard from going to a landfill! It was easy to fix with your information."
SOURCE: as i play notes on
Check if you MIGHT be in a "guide" or learning mode. Some Yamaha synths have a mode that will play and then wait for you to hit the right key before moving on. If this is not the problem, a fix is not DIY and will require repair. I assume you are NOT using MIDI as in that case it is called "dreaded MIDI drone" and is due to data looping back into the unit which is an external fault.
Have a professional tune it for you. It may be that some strings have loosened/tightened.
