Weslco cadence 825 treadmill has no power
Please watch this Video:
use the patience, carefully, and basics toolsDvom
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
To use theseinstructions, you need to have a familiarity with electricity and a workingknowledge of a voltage multimeter. With all of these tests, USEEXTREME CAUTION!!! Never let the voltage ground directly to any part ofthe treadmill or your leads ground while you
are testing voltage.
1)To begin, set your volt meter to AC volts. We are going totrace the power from the wall outlet through the
treadmill to see where it ends.
2)
With the treadmill unplugged, test the wall outlet. You should have from 115 to125 VAC. Optimally, you will
have at least 120 VAC.
3)Follow the power leads from the power cord to the lead ends.With the treadmill unplugged, connect your
meter to the lead ends. Plug the treadmill in and check your reading. It shouldbe the same as your reading
from the wall outlet.
4) Continue this process with the electrical system, following theleads, as they pass through, breakers, fuses,
and the like.
5)Where the power flow ends is where your problem is. Sometimesit will be in a bad connection, sometimes
it will be in a shorted breaker or blown fuse, at times it may be as simple asa safety switch not working
properly, or it may be a major problem with a component.
6) In some cases, components work in tandem (i.e.- a controllermay need a signal from the console
computer to release voltage to the motor)
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
