Sony Bravia L-series Kdl-32l5000 32-inch 720p Lcd Hdtv, Black Logo
A
Anonymous Posted on Apr 08, 2014
Sony bravia volume control not working with FIOS STB
Verizon FIOS STB (MOTOROLA QIP2500-3/remote (RC1445302/00B will not control volume on TV, used sony remote codes0027, 0861, 1127, 3002, 3050, 3054, 3069, 3077, 3103, 3116, 3123, 3126, 3143, 3150, 3151, 3155, 3178, 3198 none work! Any suggestions are welcome, thank you in advance.
Melanie Herr
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2014
Melanie Herr
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
306
Points
Found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
5 Related Answers
A
Anonymous
  • Posted on Feb 24, 2008
SOURCE: Picture problems
I noticed that the "wide screen" button has 4 different options that should remedy this.  I think some of them are, "full scree, zoom, zoom wide, and normal".  hopefully this will help you out
Anonymous
  • 10594 Answers
  • Posted on May 27, 2008
SOURCE: Remote
Hello creyn,
why dont you join both TV n Theater system remotes togather with rubber band?
Anonymous
  • 93 Answers
  • Posted on Feb 08, 2009
SOURCE: No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Anonymous
  • 3 Answers
  • Posted on Jun 02, 2009
SOURCE: Unable to control audio after playing a DVD using HDMI
you may have a damaged remote circit or reciver on the dvd player or tv, look for a phone number on the instructions book to call and see if you can send it in to have it checked out
Anonymous
  • 10594 Answers
  • Posted on Feb 09, 2010
SOURCE: i have a sony bravia davhdx274 but i no longer
Remote is necessary to use this sound system as there are many functions controlled by Menu on remote.
Required remote control is available in Sony Accessories Store for $52 under following part number..
148057011 RM-ADU007 REMOTE CONTROL
Thanks.
How to get volume control on my FIOS remote with Samsung TV?
Re: How can I get the volume control on my FiOS remote to change the volume on my AV receiver?
  1. Hold down the STB button on your remote control, and press OK. Release both buttons.
  2. Key in 9-5-5.
  3. Press the device button whose volume you want to control by default (in this case, AUX).
  4. Press OK.
https://forums.verizon.com/t5/Fios-TV-Technical-Assistance/How-can-I-get-the-volume-control-on-my-FiOS-remote-to-change-the/td-p/246987
1helpful
I need the remote code for the insignia sound bar to use with my verizon fios remote control
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
2helpful
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
3helpful
I have a Motorola QIP6200/64xx DVR set-top box thru Verizon
The best code I could find was "007"
"210" kind of works, but can't compete with Mr. Bond.
After programming "007", if there are any features of you FiOS remote that do not work on the HK AVR 354 remote, simply follow the HK AVR 354 manual instructions to "learn" additional commands. See the last paragraph on page 31 through letter "e" on page 32.
Cheers,
Jeremiah Pattison
Keywords: Harman Kardon AVR 354 remote code to control FiOS DVR PVR STB cable box QIP 6416
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
9helpful
2answers
Cant use fios remote to power/volume
Yesterday I called Dynex at 1-800-305-2204. The rep gave me 0463 which didn't work when I called VERIZON FIOS but the Dynex rep did inform me during the call that if it didnt that Dynex is comparible with Orian, Emerson, Memorex, Sansui, Sylvania and Zenith. So any of these tv codes should work. The code of Orian which is 0490 indeed worked!!!! And when you call Verizon make sure when they help you program your remote that they do the second step if they dont tell you which is add the code 799 which will let you just push STB then Power to cut on/off the tv. My bedroom tv, I always pretty much had to use the tv remote to cut on and off but when the Verizon rep gave me that step for the original tv I was having problems with told me this step, I had her walk me through the other tv remote and add that code and its great. She said that alot of technicians just been taught the other way. Hope this info help you.
4helpful
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
2answers
Verizon remote control code for Sony Bravia XBR
Got an older model sony xbr 36 tv. Wanna program it to work with mt time warner cable. How do i do it. Yhe TV is about 4 -5 yrears old.
1helpful
2answers
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
17helpful
10answers
Code for Verizon FIOS remote Control
I have a solution which has worked well for me. It uses the DVD button at the top of the remote. It was a trade-off as none of the codes in the RC144 Philips remote will work any Blu-ray players, so the DVD button was unassigned. The 922, 955 and 977 codes are explained in the directions for the FIOS remote. http://onlinehelp.verizon.net/consumer/bin/pdf/philips%20rc1445302%20user%20guide.pdf
1. Set up your TV button to work your TV.
2. Set up your Onkyo code, pick one to turn on the receiver. I used 3719
3. Use the 9-2-2 code to cycle through all available codes. At about a count of 300 I found one which will turn the Onkyo receiver off. Make sure you start this process with the ONKYO receiver already on. Once you find it press the OK button.
4. Use the 9-7-7 code to power all devices TV, AUX and DVD from the power button.
In this way, each time the power button is pressed it will send both the power on and power off signal to the ONKYO receiver.
This technique works well when you point the remote at the ONKYO receiver and press power button. Apparently the TV has better reception for the signal then the ONKYO does.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
