SOURCE: Mitsubishi WS65905 Projection TV
convergance ics and sometimes resistors go bad. call a repairman...
SOURCE: Picture bends in different colors
your Convergence IC chips and resistors arre failing you need to replace them
below is a general disscussion post for a Philips TV which will help you to understand your situation and what you might need usally you will need (2) IC convergence Chips and usally (12) Resisitors what have to be soldered onthe the board after you remove the old ones. this fix usally cost you to do it yourself $30, to have a repair man do it cost around $300-450 a new board if avalible usally costs $250-300
Sorry, for the bad new I hope you have a friend that knows how to work on circuit boards...
good luck,
below is a general post about a philips TV Convergence problem you can read about keep inmind your CHIP and RESISTORS will proball be different type....
you need 2 Convergence IC's STK392-120's (120's and 150's will work) of course order 2 of the same type I'm using replacement 150's they allow for a little higher heat and were cheaper ALSO you need to replace the 12 resistors with 6.8 ohm metal film resistors, make sure they are metal film! don’t skimp out here I did and then they blew and fried my IC's and I had to replace everything again!
Great reference link that I posted pictures on, check out page 3
http://www.techlore.com/forum/thread/16736/Magnavox-51MP392H-17-51-quot--TV-has-double-vision/
Where I got my parts that worked:
Suburban Electronics http://www.suburban-elect.com/
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
What you need:
(2) STK392-120 OR STK392-150 IC chips
(12) 6.8 Ohm Metal Film resistors
set of star screw drivers
15 watt pencil solder pencil, DO NOT use a high watt iron you will fry the surface mounted item.
good leaded solder, and flux
SOURCE: There is a green glow around everything in the
I am going to post some photos here for you. If you went into the customer menu and tried to adjust convergence and red and blue would move but green is skewed--you have a convergence problem.
Look at the photos and tell me if any look ANYTHING like your trouble. If you have a convergence problem with this model I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS I CAN GIVE YOU.
If this helped you rate this solution as I do this here for free.
SD TECH
Photos:
OR?
Testimonial: "Thank you very much. Its somewhat like that but there isn't any ghost image, its more of a green outline around the images.there is alot of red in pic"
