Kenwood KDC-MP4028 CD Player Logo
A
Anonymous Posted on Apr 09, 2014
I need a unlock code for my kenwood kvt 514 car stereo cause it locked an i dont know the code
5 Related Answers
Anonymous
  • 1498 Answers
  • Posted on Sep 01, 2008
SOURCE: unlock code for kenwood model kdc mp5028
Hey there joe,
Click here, it will bring to a Tip page authored by one of our best technicians (Robotek). He outlines the procedure for clearing the code on most Kenwood models.
If this gets you going, don't forget to give Robotek a rating Remember: Good things come to those who Rate!!
Mike
Anonymous
  • 34 Answers
  • Posted on Jan 08, 2009
SOURCE: UNLOCK SECURITY CODE
for your kdc-mp528 will work whith code KCAR entered from the remote
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press and hold the "Auto" button and "Track up" (next track button on the right) on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
i hope this works for you.
Anonymous
  • 14 Answers
  • Posted on Feb 04, 2009
SOURCE: need the un-lock code for a kenwood kdc-422 car cd player
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Anonymous
  • 863 Answers
  • Posted on Nov 23, 2009
SOURCE: no lock code for car stereo
Here you go buddy:
http://www.fixya.com/support/r538828-security_unlock_code_kenwood_most_models
Anonymous
  • 5 Answers
  • Posted on Feb 17, 2010
SOURCE: i need the Kenwood KDC-MP438U user manual
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear,then enter kcar using your remote,i just did it,it works
Have a kenwood kvt-514 but don't have the rca cables to connect to the amp how do i connect the deck to the amp
Ozzie my car was burglarized and had my code to my kenwood owners manual now can’t turn my kenwood kvt 514 unit back on can you please help
Help me crack the security code on my kenwood KVT-514 DVD car stereo????
Here's a video tank daWG suggested as a solution to your problem from YouTube:
how to unlock code kenwood stereo.3gp
1helpful
How can I update tha software for keenwood KVT-514
Try this link. http://www.helpowl.com/p/Kenwood/KVT-514/Research/53126?search=Kenwood+Kvt-514+Update&x=79&y=17
Codigo de seguridad de kenwood kvt-514
buenas,, hace tiempo compre un repro kenwood kvt-514 y al encenderlo me sale en la pantalla CODE SET y no tengo el codigo,, hay manera de desbloquearlo sin el codigo que me solicita...???
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
KVT-512 Car DVD Player: Battery was disconnected ans car stereo locked out...
Sorry...KENWOOD codes are only available from the Main Dealer or a Radio Decoding Service
5helpful
How to unlock code for kenwood kvt-514
Did anyone ever figure this out? I need to know also
1helpful
Dont know the security code for kenwood kvt 617 dvd unit how can i unlock the code
a new eprom chip has to be installed,and proof that you did not steal the set.
best way for your tv not to get stolen is to leave a post it note that it is locked.
it is like passwording a computer,the hard drive needs to be formatted.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
