SOURCE: Unable to load desktop ASUS 1005HA XP SP3
Hi
It seems you are stuck in a windows loading loop
Please do the following
1) Go into safe mode (swith the pc on and keep pressing F8 repeatedly until you have a menu presented to you, from the menu choose safe mode)
2) Once loaded click on Start>Programs>Accessories> System Tools> System restore
And restore your computer back to a point before the update was done
if it still loops when using safe mode through the method shown above then unfortunaltey you will have to reformat the PC
Please can i ask that you leave feedback and vote if this has been useful
SOURCE: Accidentally erased hard drive on Asus 1005HA Eee
Sir,
You have to reinstall your operating system using a cd / dvd and then you can retrieve the data you have erased using the software .Click the below link for the software.
Data Recovery Software
SOURCE: a new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
SOURCE: my asus notebook eeepc 1005ha does not start, my
What happens when you start the computer?
Since when is this happening?
Did you make any hardware or software changes?
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
