SOURCE: what cables do i need to connect my acer laptop to
usb cable and external usb dvd reader. it can be done with a thumb drive with a bit of work also.
There is a setting in bios for install, and you should make sure bios is set to boot from either external cd/dvd or thumb drive depending on how you are installing. once the installation is complete you should on next reboot change the bios setting from install to normal, otherwise the usb port will operate at 1 speed instead of 2 which is annoying.
