I performed a factory reset on my hp slate 7 tablet and instead of the hp symbol coming up the ftm symbol came up. Prior to performing the reset the touchscreen was unresponsive and the guidance from the hp support site suggested performing a factory reset.
SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
SOURCE: Coby touchscreen internet tablet for android will
I would guess that it overheated. You aren't supposed to leave them plugged in for extended periods of time.
SOURCE: How do you change the display on the HP tablet
right click on the screen at the bottom is properties
click that then i think you want settings near the bottom are three buttons the one to the right should be advanced you should be able to change that in there
SOURCE: How to reset Pandigital 7 in. Planet Tablet to
There are two ways to do it. You can either update the firmware and it will erase everything for you, or you can do a factory reset, and return to factory settings. Go to Settings, PDN settings (not the Android settings menu) and scroll right to the Reset Defaults location. Tap on the reset button and you will be taken back to factory default settings. It might take a while to reload, but after everything it will be back to factory defaults from when you first bought it. Updating the firmware might be your best option if you care to resell it, because it may cause less issues for the next person and less chance of any returns.
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
