Washer is not draining. Error display is OE. Drain filter is clean. Cannot clean drain hose
SOURCE: model dwd1410ds,it wont drain.error OE.have
Although I do not know your particular model here is an extract from my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
ENSURE POWER IS OFF!
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
Hello &
Welcome to FixYa
other questions.
Kevin
That's must be frustrating to not be able to clean the drain hose. The drain in my kitchen also needs to be cleaned because I'm nervous to try it myself. I bet that a plumber would be able to clean the drain hose for you though, maybe I'll find one myself.http://www.coxconstructioninc.net/drain-...
