Question about Sony DAV-SB100 System
How do I unluck Sony DAV-TZ710
Eject button can not eject disc. When I press eject, it shows locked on display
5 Suggested Answers
Anonymous
SOURCE:
Kris Wingert
  • 97 Answers
SOURCE: Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Posted on Jun 11, 2007
lu3k
  • 3 Answers
SOURCE: Lock and Demo Play Display
while the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out.
In some models you need to turn off the power and turn it on while pressing the EJECT Butoom.
SONY SPECIALIST
Posted on Nov 24, 2007
asnowman
John Snow
  • 788 Answers
SOURCE: DVD stuck inside sony dav-sc5.
Have you tried to unplug the unit for 1 or 2 minutes to see if it can reset the computer chip inside of the DVD player?
I have had great sucess with this trick.
I hope that this helps you out of this situation.
asnowman
Posted on Feb 08, 2010
SOURCE: SONY DAV-FX900KW - I am
there is a small circle just beneath the CD tray. If you click it using a toothpick or any tiny device, it will help eject the disk. I have tried that and it works... There might be a problem on the roller inside the disk tray, wherein it requires a technician to repair such device...
Posted on Dec 19, 2010
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
If press eject button,it's showing LOCKED.what can i do?
You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
Jan 21, 2015 | home Audio Players & Recorders
My panasonic dvd player shows locked when I tried to eject. I can't eject tehDVD. My kids could have jinxed it. Model panasonic sc-pt550 TQ
There are two lock conditions for this device.
If you can't eject the disc:
Enabling removal of disc
1. Select the DVD/CD function.
2. At POWER ON condition, press and hold down the stop button and the power button on the player for at least three seconds.
(The message, "___LOCKED_" appears when the function is activated.)
If you can't operate the functions:
Enabling operation of selector and disc
2. At POWER ON condition, press and hold down the play button and the power button on the player for at least three seconds.
Hope this helps!
Apr 08, 2011 | Panasonic DVD-S52 DVD Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Cannot eject disc after recording program.
There maybe a manual release on the underside of the player look for a hole that you can slide across this will release the tray.
Dec 09, 2009 | Panasonic DMR-ES35VS
Hi- I've just inserted a CD into my MacBook Pro
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 13, 2009 | Apple MacBook Pro Laptop Computer with...
Cannot close disc tray
The dealer lock feature was intended to prevent theft of discs when on display at the retail location. To shut it off, you press and hold the "stop" button on the front panel of the player. While holding that, simultaneously press the "power" button on the remote control. You can release both buttons now. A message will say "dealer lock off" and now you can eject the disc.
Sep 27, 2009 | Koss KD260 DVD Player
Disc does not eject on HDR UX7
Please press eject button and in same time press reset button.
In display you see "you sure open dvd case" and you answer is "yes".....
Disc eject on HDR-UX7 for me.....
Sanurax
Dec 17, 2008 | Sony Handycam HDR-UX7 Camcorder
SONY SPECIALIST
Dec 29, 2006 | Sony DAV-X1 System
Sony DAV-SB100 System Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
