SOURCE: I cannot get my roadrunner mail to work on my
Hi. Try this torubleshoothig steps. Delete the mail account and start over with the defaults ... Or start here => For the SMTP server, use host "smtp-server.nc.rr.com", change the default port from 587 to port 25 (in coming pop server should be 110 by default). If you have mail in your Outbox you will get a error message that you cannot connect, delete all mail in Outbox, now try sending yourself mail.
SOURCE: I have just got an
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
SOURCE: I cannot access old Outlook (2007) emails on my
1)Press settings icon (the one with the cogs)
2) than scroll to Mail, Contacts, Calendar and press it.
3) Find your email account you want to modify and click it
4) find the section on the bottom that says "Mail Days to Sync and press the button
5) Now, you have limited options there, but you can pull email from 1,3 days or 1,2 weeks, 1 month or No Limit. If you click no limit it will pull your entire inbox. So, I might be careful in saying it will drain battery power. And or take room on your ipad away. So, if you have old emails with big attachments, be weary. Plus, depending if you are pulling all this mail over 3G you should take note of your data limits.
Hope that helps.
SOURCE: good day, i can't see my emails in my email
To check for account tap settings and tap mail,contacts.calendars.Under accounts see if any listed.If account is not listed tap add account and choose service then sign in.If listed choose account and check settings for correct address and password.Click done when finished
SOURCE: iPad 2 just closes my emails in the middle of a reply. Why?????
Maybe the OS is not so stable, or it gets a virus. Suggest you to scan it and try, if not work, it's better to take it back to Apple for help.
Android 4.0 Tablet PC
1. Tap the Mail icon at the bottom of the home screen on iPad.
Step 2. Then tap to add type of email account that you want at add among: Microsoft Exchange, Mobile me, Gmail, Yahoo Mail, AOL or others. For example, if you want to add a Yahoo mail, just tap the Yahoo mail as follows:
Step 3. Then enter login details for selected email account type.
It will configure automatically and you should able to send - receive emails.
