Can you date this Peavey Fury 4 Quilted bass guitar from the serial number 01050957 and where manufactured the number is ink printed on the rear of the headstock
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
SOURCE: My BBN4 Yamaha bass has the 3&1 tuner
Check www.yamaha.com/apps/guitararchives/guitarserial.html
It gives dates from old serial numbers
SOURCE: volume control of peavey bass guitars
Sorry but your post did not provide enough info. Are you having a problem with the volume control. Do you need a wiring diagram. What model Peavey bass do you have. For instance, the Peavey bass I have has active electronics ans requires a 9 volt transistor radio battery to power them.
SOURCE: I want to date a Peavey Fury bass. The serial# is
Hi. You can email peavey at [email protected] and send them your inquiry. They're have that sn archived. I hope this helps. :-)
SOURCE: peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Testimonial: "Thanks for the recommendations. I will keep them in mind."
SOURCE: fender serial number lookup
I think it is from 1976 You will need to take it to a music shop to get the value.
