The S4000 uses standard AA batteries. If you use rechargeable batteries, you must charge them using a separate charger---the S4000 does not charge batteries. You should be able to find AA rechargeable batteries and battery chargers at just about any department, electronics, or office-supply store.
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
If your Nikon EN-EL10 battery for your Coolpix S4000 won't be charged, there seems something wrong with your battery or battery charger, so you need a new one.
The problem about lens, if something was loose, there maybe a screw and after a term it may cause lens error.
The S4000 uses SD cards up to 2GB in size and SDHC cards up to 32GB in size. Don't worry about the make of the card, as long as you stick with the major brands (Lexar, PNY, SanDisk, etc).
I would recommend you to buy Nikon Coolpix S4000Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000.http://hubpages.com/hub/Nikon-Coolpix-S4000-12-MP-Digital-Camera
I would recommend you to buy Canon PowerShot SX210IS 14.1 MP Digital Camera with 14x Wide Angle Optical Image Stabilized Zoom and 3.0-Inch LCD.Decidedly slim and sleekly refined, the PowerShot SX210 IS packs a feature set that reads like a wish list. The 14.1 Megapixel CCD joins a 14x 28mm Wide-Angle Zoom for imaging power to spare. Frame your shots in the bright 3.0-inch widescreen PureColor System LCD, with the Low Light mode for sharp images in dimly-lit situations. It also captures stunning HD movies with Dynamic mode for enhanced image stabilization when shooting movies using wide-angle settings. Capture smooth HD video (720p) with stereo sound for a truly natural, high-quality HD experience. The PowerShot SX210 IS not only goes wherever you do, but takes your photography and video to a whole new place, too.
You can check out more detailed review for PowerShot SX210 IS
http://hubpages.com/hub/Canon-PowerShot-SX210IS-Digital-Camera
MetroPCS provider
Kyocera Mako S4000
Screen is blank, no visual.
Phone works but the screen is blank.
Can this be fixed? What are the steps to fixing this blank screen?
